Top » Optional Products/Software » Removable HDD Kit » Setting/Removing the Hard Disk Holder
0R9W-04Y
This section describes how to set/remove the hard disk holder of the Removable HDD Kit.
Do not set/remove the hard disk holder when the machine is performing operations. Doing so may cause damage to the hard disk.
To set/remove the hard disk holder, first eliminate the static from your body. Also, do not touch the connector.
A hard disk is fragile equipment. Note that Canon will not be liable for any damages resulting from the loss of data on the hard disk drive.
Setting the Hard Disk Holder
Hold the handle on the hard disk holder and being careful of the orientation, insert the holder in until it clicks.
Lock the hard disk holder with a padlock.
Make sure to lock the hard disk holder to the machine to prevent theft.
Hold the handle on the hard disk holder and remove the holder.
Do not store the hard disk holder in the upright position, as doing so may damage the holder. Store the hard disk holder with the hard disk side on the top.
If the hard disk holder is locked to the machine, unlock it first.
A lock is not included with this machine. Purchase a lock that is commercially available for security reasons.
Note that Canon will not be liable for any damages resulting from the hard disk drive being stolen.
