Setting a Department ID and PIN Beforehand
0R9W-18S
You can save a department ID and PIN in the Color Network ScanGear 2 Tool, so that the saved department ID and PIN are automatically used for authentication when scanning.
Start Color Network ScanGear 2 Tool → select the scanner.
Confirm that [Enabled] is displayed for [Dept. ID Management] → click [Dept. ID Settings].
Select [Save PIN] → enter the department ID and PIN → click [OK].
If a PIN has not been set at the scanner, leave the PIN setting blank.
4.
Click [Exit] in the Color Network ScanGear 2 Tool.
The window displayed may vary according to the operating system etc.
The descriptions and explanations herein are given using images from Color Network ScanGear 2.
