Icon (Job Status)
Description
Executing
Waiting
Interrupt/Priority Printing
Error
Canceling
Paused/Need Paper
Secure Print
Encrypted Secure Print*
Sent
Before Output
After Output
This icon appears only when the appropriate optional products are available for use. For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Icon (Job Type)
Description
Copy Job
Print Job
Send/Fax Job
Mail Box Job
Received Job
Network Job
Memory Media Job
Report Print Job
The number of jobs displayed for the job history is indicated below.
*100 total jobs are displayed for sending and receiving.
If [Display Job Log] in [Management Settings] (Settings/Registration) is set to 'Off', [Job Log] for each screen is not displayed.
You can set the screen displayed when [Status Monitor/Cancel] is pressed in [Default Screen (Status Monitor/Cancel)] in [Preferences] (Settings/Registration). (See "Default Screen (Status Monitor/Cancel).")
If [Display Job Status Before Authentication] is set to 'Off', operations other than displaying the Device Status screen cannot be performed even when you press [Status Monitor/Cancel], unless you have logged in to the machine. (See "Setting the Control Panel Display.")
Many of the check/change operations can also be performed from the Remote UI. (See "Managing Jobs.")
The status bars on the keys for selecting a job type, flash in green or red to indicate the status of jobs. The status bars flash green when there are current jobs that are being processed, and maintain a steady green light when there are jobs in the print queue. Flashing red status bars indicate errors. For instructions on resolving errors, see "List of Error Messages."
The Fax function is available only if the optional product is available for use. For information on the optional product required to use the Fax function, see "Optional Products Required for Each Function."
