Top » Flow of Settings » Sending Data to a File Server
0R9W-00A
The following operations and settings are required to send data to a file server with the machine.
For information on the system requirements for using this function, see "Sending Data."
The file servers you can use differ depending on the network you are using. For information on the file servers you can use, refer to the following, according to the network you are using.
1. Connect the machine to the network.
2. Set the machine for the type of network you are using.
For a TCP/IP network:
For an SMB/CIFS network
3. Set up the file server.
For an FTP server
For a WebDAV server
For a Windows shared folder/Samba shared folder
To Practical Workflows
Scanning the Original and Sending to a Computer
