Top » Quick Menu » Using the Quick Menu from the Machine » Restricting Access to the Quick Menu
0R9W-19F
You can set whether to allow general users and unregistered users to register or edit Quick Menu buttons.
This operation can only be performed by a user with the required privileges. For more information, see "Setting Administrators."
If authentication is not set, the Personal buttons are not displayed.
Press [Quick Menu].
Press .
Press [Restrict Quick Menu Use].
4.
Set Restrict Quick Menu Use → press [OK].
<Register Shared Buttons>:
If you set <Register Shared Buttons> to [On], general users and unauthorized users can register, edit, or delete the Shared button, or change the size of buttons and the wallpaper image.
<Use Personal Button>:
Select [On] if you want to use Personal buttons.
<Authentication Default Screen>:
Select [Personal] or [Shared] to set default screen that is displayed after authentication.
