For a landscape document, one side is copied top-to-bottom and the reverse side bottom-to-top when <Book Type> is selected. When <Calendar Type> is selected, both sides are copied top-to-bottom.
Adjust the document guides to fit the document.
Make sure that the number of sheets or the paper type loaded in the paper drawer or multi-purpose tray meets the paper specifications.
Adjust the paper guides to the paper size. If the problem persists, load paper with the other side face up, or in an opposite orientation.
Make sure that the document return tray or output tray is not full.
Follow the onscreen instructions and solve the problem.
Split the document into smaller subsets or set <Original Type> to <Text/Photo (Quality)> before you make a copy.
You may be able to improve the problem by setting <Background> to <Off>.
However, back-printing may occur.
Perform <Copy Image Adjustment> again.
Before doing so, place ten sheets of blank paper on the test chart placed on the platen glass.
Up to fifty documents can be loaded in the feeder. The fifty-first and subsequent documents are not scanned.
