Before correcting copy images, see "Attention (Correcting Copy Images)."
When copy image correction can be performed
The following messages are not appeared in the display.
<End of Cart. Life.>
<Prepare toner cartridge.>
There are no jobs which use the scanner functions and printer functions.
The following paper is loaded in the paper drawer.
- Paper Size: A4 or Letter - Paper Type: Plain paper or Recycled paper - Sheets of paper: 1 sheets or more If you execute copy image adjustment with running out toner
Even you try to perform the adjustment; the image may not be improved.
Change the toner cartridge and redo the adjustment.
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
A test chart (adj. image 1) is printed.
] (Start).
Check the temperature of the installation site
If the room temperature is too low, correction may not be performed properly.
If <Adjustment failed.> appears |
Is the paper loaded correctly?
Is the test chart placed on the platen glass correctly?
Has a paper jam occurred?
] (Menu) to close the menu screen.
