The document loaded in the feeder cannot be previewed.
To perform all the operations on the toolbar, the preview image is required.
] (Clear) |
Deletes the preview image. The settings for the toolbar and color are reset.
] (Crop) |
Specify the scanning area.
] (Move) |
Moves the enlarged image.
] (Zoom) |
Enlarges or reduces the preview image.
Left-clicking
Enlarges the image. Right-clicking
Reduces the image. |
] (Left Rotate) |
Rotates the image 90 degrees in the left.
] (Right Rotate) |
Rotates the image 90 degrees in the right.
] (Information) |
Displays the information of the scanned image.
] (Auto Crop) |
Selects the cropping area of the image automatically.
] (Remove Cropping Frame) |
Deletes the selected cropping frames.
[Select All Crops]
All the cropping frames reflect the settings made on the [Advanced Mode] tab.
[Zoom]
Rescan the focal cropping area of the preview image at a higher level of magnification.
Once clicked, this button changes to [Undo].
Items that cannot be registered in favorite settings
Values of width and height in [Input Settings] and [Output Settings]
Activation of the [
] (maintaining the proportion of width and height) button in [Input Settings]Value of [%] (Scale) in [Output Settings]
[User Defined]
Enter and specify each setting value.
[Default]
Resets the current setting to the default value. The preview image is deleted.
[Add/Delete]
Displays the [Add/Delete Favorite Settings] dialog box. You can name and register the current preview image settings. This item is not displayed when there is no preview image.
[Original Input Method]
Selects an input method from the following settings.
[Platen Glass]
[ADF (1-sided)]
[ADF (2-sided)]
[Input Size]
Select a size of the document to be scanned.
If you selected [Platen Glass] or [ADF (1-sided)] from [Original Input Method], you can also enter values to specify the size.
Specifies the width of the input size. Specifies the height of the output size.
] (Original Orientation) |
Shows the direction of scanning paper.
The icon to be displayed varies depending on the settings for [Original Input Method], [Input Size], and [Orientation].
[Orientation]
Click to specify the orientation of the document.
If you selected [ADF (2-sided)] from [Original Input Method], you can also specify [Binding Location]. If you selected [Platen Glass] from [Original Input Method], this setting is unavailable. |
[Color Mode]
Selects the type of document and the way in which it is scanned.
[Black and White]
To output documents in monochrome. The image color is divided into white and black at a certain level (threshold), and the image is expressed in 2 colors. See "Color Settings" for the instruction on how to specify a threshold value. [Grayscale]
Select when scanning black and white photos or monochrome images. The image is expressed in a 0 to 255 scale of black and white. [Color]
Select when scanning color photos. The image is expressed in 256 levels (8-bit) of R(ed), G(reen), and B(lue). [Color (Documents)]
Select when scanning documents that contain text or tables. The image is expressed in 256 levels (8-bit) of R(ed), G(reen), and B(lue). [Text Enhanced]
Scans text clearly. Select when scanning text using OCR software. The image is expressed in 2 colors of black and white. |
[Output Resolution]
Select the scanning resolution from the drop-down list or enter any value between 25 and 9600 dpi to specify the scanning resolution. If you want to use the feeder or the platen glass cover, enter any value between 25 and 600 dpi.
[Output Size]
Select the output size of the scanned image.
If you select [Add/Delete]
The [Add/Delete the Output Size] dialog box will appear, and you can add and delete the custom output size. If you select [Flexible]
Enter values for width, height, or [%] (Scale). The ratio of width and height is proportionate to the width and height in [Input Settings]. The actual scanning resolution varies depending on a value specified in [%]. You can enter the value for [%] between 25 and 38,400, but the upper limit varies depending on the value of [Output Resolution]. Click [
] to change the layout orientation (landscape or portrait). When selecting [Flexible], you cannot use this button. |
[Data Size]
Displays the data size of the image scanned using the specified settings.
[Auto Tone]
If [On] is specified, the color tone for the image is adjusted automatically. You can apply this setting when the preview image is displayed.
[Reduce Dust and Scratches]
Reduces dust and scratch marks on photos.
[None]
No reduction of dust and scratch marks will be made. [Low]
Reduces only small dust and scratch marks. [Medium]
Normally this setting is recommended. [High]
Reduces large dust and scratch marks. This may remove delicate parts of the image.
[Fading Correction]
Corrects faded images. Selecting this option enhances the saturation of faded documents, making the image vivid. You can apply this setting when the preview image is displayed.
[None]
No fading correction will be made. [Low]
Corrects faded images slightly. [Medium]
Corrects faded images highly. This may change the tone of the image.
[Grain Correction]
Smooths out the film grain of the image recorded on fast film. The result is smoother tones and higher overall quality.
[None]
No grain correction will be made. [Low]
Select this setting when the grain in the picture is not so notable. [Medium]
This setting is recommended. [High]
Smoothes out even very notable grain in the picture. This may lower the image sharpness and tonal quality.
[Use Unsharp Mask]
If this option is selected, outline of the image is emphasized, making it sharp. It is effective for scanning photos etc., which have a soft focus.
[Use Descreen]
Select to reduce the distorted pattern (moire) when scanning printed photographs and pictures.
[Black Text Correction]
If the check box is selected, emphasizes the outline of black text.
] to adjust the brightness and contrast diagrammatically.
[Channel]
Select a color to adjust either [Red], [Green], or [Blue], or select [Master] to adjust all three colors together when [Color] or [Color (Documents)] is selected in [Color Mode].
When [Grayscale] is selected in [Color Mode], adjust gray color.
[Brightness]
Adjust the brightness by moving [
] on the slider or manually entering values from -127 up to 127. |
[Contrast]
Adjust the contrast by moving [
[Reset]
Resets all the current settings to their default values.
[Channel]
] (Black-point eyedropper tool) |
Click this button and specify an area which you want to darken the most by clicking in the preview image (or the selected cropping area). You can also manually enter a value from 0 up to 245 or move [
] on the slider. |
] (Mid-point eyedropper tool) |
Click this button and specify an area where you want to make halftone by clicking in the preview image (or the selected cropping area). You can also manually enter a value from 5 up to 250 or move [
] on the slider. |
] (White-point eyedropper tool) |
Click this button and specify an area which you want to lighten the most by clicking in the preview image (or the selected cropping area). You can also manually enter a value from 10 up to 255 or move [
] on the slider. |
] (Gray Balance eyedropper tool) |
To adjust color images, click this button and specify a point at which gray balance is adjusted by clicking in the preview image (or the selected cropping area). The gray color in the scanned image becomes halftone, and other colors are reproduced in their original colors.
[Reset]
[Channel]
[Select Tone Curve]
Select a tone curve type from [No Correction], [Over Exposure], [Under Exposure], [High Contrast], and [Invert the Negative/Positive Image].
[Reset]
Threshold
Brightness of color and gray images is expressed by a value between 0 and 255, while brightness of black and white images is expressed by white or black, including colors between black and white. The boundary to divide colors into white and black is called "Threshold."
[Threshold Level]
Adjust the threshold level by moving [
] on the slider or manually entering a value from 0 up to 255. |
[Reset]
[Custom]
You can specify each setting value. The settings can be changed even after applying them.
[Add/Delete]
Opens the [Add/Delete Tone Curve Settings] dialog box ([Add/Delete Threshold Settings] dialog box for when [Black and White] is selected in [Color Mode]). This dialog box enables you to name and register a set of color settings.
[Preview at the Start of ScanGear]
Selects the preview operation when you open the ScanGear MF.
[Automatically Execute Preview]
The preview starts automatically when you open the ScanGear MF. [Display Saved Preview Image]
Displays the image last previewed. [None]
The preview image is not displayed. |
[Cropping Frame on Previewed Images]
Sets how the cropping frame is displayed when you preview images.
[Execute Auto Cropping on Previewed Images]
The image will be automatically cropped to match the document size. [Display the Last Frame on Previewed Images]
Displays the last frame. [None]
No frame is displayed. |
[Scan without Using ScanGear's Window]
If you are using an application such as OCR software that does not display the ScanGear MF window when scanning, documents are scanned with the application settings. If you want to scan in a specific color mode without using the application settings, specify the setting in this option.
[Color Mode (Text and Table)]
The document is scanned in a mode equivalent to [Color (Documents)] of [Color Mode], regardless of the application settings. [Text Enhanced]
The document is scanned in a mode equivalent to [Text Enhanced] of [Color Mode], regardless of the application settings. |
[Automatically Quit ScanGear after Scanning]
If this item is selected, the [ScanGear MF] dialog box closes automatically after scanning. Depending on the application, the ScanGear MF closes automatically after scanning, regardless of this setting.
[Color Correction]
Selects the type of color correction.
[Recommended]
Vividly reproduces the tone of a document on the screen. [Color Matching]
Adjusts color to that of the scanner, monitor, and color printer. If this item is selected, the color setting buttons in the [Advanced Mode] tab are disabled. This setting is available when [Color], [Color (Documents)], or [Grayscale] is selected in [Color Mode]. |
[Always Execute the Auto Tone]
Always corrects the image color automatically. This setting is available when [Color], [Color (Documents)], or [Grayscale] is selected in [Color Mode].
[Monitor Gamma]
Adjusts the gamma. You can specify the gamma value (0.10 to 10.00) of the monitor which displays the scanned image. This setting is not reflected in the scanning result when [Black and White] is selected in [Color Mode].
[Select Folder Where Temporary Files are Saved]
Specifies the folder to save images temporarily. Click [Browse] to specify a folder to save the file.
[Sound Settings]
Sets the scanner to play music during scanning or play a sound when scanning is complete.
[Play Music During Scanning]
Music is played during scanning. Click [Browse] and specify a sound file. [Play Sound When Scanning is Completed]
Music is played when scanning is completed. Click [Browse] and specify a sound file. You can specify the following files:
MIDI files (*.mid, *.rmi, *.midi)
Audio files (*.wav, *.aif, *.aiff)
MP3 file (*.mp3)
[Test Scanner]
You can check if the scanner is functioning properly. The [Scanner Diagnostics] dialog box is opened. Click [Start].
