When enlarging/reducing a printing image
When printing an image with the length and width doubled, the actual resolution becomes half. In this case, you can print in sufficient quality by scanning the document in double resolution. Conversely, when printing an image with the length and width halved, you can print properly in half resolution.
Resolution and data size
When resolution is doubled, the amount of the scanned image data is quadrupled. If the data is too large, this may slow the processing speed substantially, resulting in failure such as insufficient memory. Specify the minimum resolution according to your purpose.
When printing with a color printer
Specifying the resolution at half the resolution of the printer should be fine because inks of several colors are mixed in color printing.
About the scanning resolution
The maximum resolution is as follow.
