[Photo (Color)]
Select when scanning color photos.
[Magazine (Color)]
Select when scanning color magazines. (with the Descreen function)
[Newspaper (B&W)]
Select when scanning text and line drawings.
[Document (Grayscale)]
Select when scanning color photos or text in monochrome. It is appropriate for scanning high-resolution monochrome images.
[Document (Color) ADF]
Select when scanning color documents on the feeder.
[Document (Grayscale) ADF]
Select when scanning grayscale documents on the feeder.
The document loaded in the feeder cannot be previewed.
] to change the layout orientation (landscape or portrait).
] (Auto Crop) |
Specifies the cropping area of the image automatically. For details, see the following.
] (Remove Cropping Frame) |
Deletes the selected cropping frames.
] (Left Rotate) |
Rotates the image 90 degrees in the left.
] (Right Rotate) |
Rotates the image 90 degrees in the right.
] (Information) |
Displays the information of the scanned image.
[Output Size List]
Displays the registered output size name.
[Output Size Name]
Enter the output size name you want to register.
[Width]
Specifies the width of the output size.
[Height]
Specifies the height of the output size.
[Unit]
Selects the unit of measurement for the output size.
[Add]
Adds the specified output size to [Output Size List].
[Delete]
Deletes the selected output size from [Output Size List].
[Save]
Saves the registered settings.
