Solution
Set [SD Card] to [On], and then perform a hard reset.
Solution
Perform formatting in [SD Card Maintenance] in the User Maintenance options in the Setup menu.
If the same error still occurs, replace the SD card.
Solution
Turn the printer OFF, then check if the SD card is installed properly.
Solution
Delete any unnecessary jobs from among the jobs saved on the SD card.
