You can print data by selecting the saved box or job.
You can check or operate the jobs stored in a box. You can perform operations of Resume (Print) and Delete. You can also check the jobs in detail. This operation is performed from the Remote UI.
You can change the name of the box in which data is saved or password. This operation is performed from the Remote UI.
About stored jobs
The stored jobs can be displayed or operated only when the SD card is installed, and [SD Card] is set to [On]. For details on the settings for [SD Card], see "[Setup] Menu ([Control Menu] Options)."
The saved jobs are saved on the SD card even after printing, and they are not deleted even after turning the printer OFF. When you want to delete the saved jobs, use the Remote UI.
Up to the total of 100 jobs in all the boxes can be saved.
You can change the name of the stored job in the printer driver before printing.
When the amount of data or number of jobs that you can save on the SD card exceeds the limit
The message <Cannot store.> is displayed. When the message is displayed, perform the following procedure.
Operating the Remote UI
"Remote UI."
