It explains the procedure for inserting the SD card.
Insert the SD card correctly using the following procedure.
It explains the procedure for checking whether the SD card is inserted correctly.
After inserting, perform a check using the following procedure.
It explains the procedure for removing the SD card.
Use the following procedure when removing SD cards.
