Table description
Bold values in the table indicate the default settings.
After changing the setting items with "*1", cycle the power of the printer or perform a hard reset to make the settings effective.
The setting items or setting values with "*2" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[Sleep Mode]
[Off], [Panel Off], [On], [Deep Sleep]
Set the sleep mode.
[Sleep Even if Error]
[Off], [On]
[Sleep Migration Time]
[5 minutes], [10 minutes], [15 minutes], [30 minutes], [60 minutes], [180 minutes]
[Timer Settings]
[Wake Up Timer]
[Off], [On]
Set sleep modes (panel off mode, printer sleep mode and deep sleep mode) to cancel automatically.
[Wake Up Time]
When [AM/PM] is selected in [12/24 Hour Clock]:
00:00 AM/PM to 12:00 PM to 11:59 AM/PM
When [24 Hour] is selected in [12/24 Hour Clock]:
00:00 to 12:00 to 23:59
[Sleep Mode Timer]
[Off], [On]
[Sleep Mode Time]
[Calibration Timer]
[Off], [On]
Set whether to run calibration automatically at set times.
[Calibration Time]
00:00 AM/PM to 12:00 PM to 11:59 AM/PM When [24 Hour] is selected in [12/24 Hour Clock]:
00:00 to 12:00 to 23:59 |
[Warning Step]
[Toner Cart. Warning]
[Continue Printing], [Stop Printing]
Specifies whether the printer should continue or stop printing when <Toner cartridge will soon reach end of lifetime.> appears.
[Auto Continue]
[Off], [On]
Specifies whether the printer should automatically use the function that, when an error is occurring, releases the printer from the error temporarily (Error Skip) and continues the job.
[Panel Language]
[Deutsch], [English], [Español], [Français], [Italiano], [中文(简体)], [한국어]
Specifies the language to be displayed in the display.
[Alarm]
[Off], [On]
Specifies an alarm sound for when an error occurs.
[Show Warnings]
[Off], [On]
Specifies whether the printer should display
<16 C toner cart. will soon reach lifetime.>
<16 M toner cart. will soon reach lifetime.>
<16 Y toner cart. will soon reach lifetime.>
<16 K toner cart. will soon reach lifetime.>
when the toner cartridge needs to be replaced soon.
[Drawer Empty]
[Off], [On]
Specifies whether the printer should blink the Paper Source indicator for the paper drawer that ran out of paper.
[E-Mail Trans. Error]
[Off], [On]
Specifies whether the printer should display an error message when a communication error occurs in the e-mail printing.
[Date/Time Settings]
[Date]
01/01/2001 to 31/12/2030
Specify date or time when the clock is not keeping correct date or time.
[12/24 Hour Clock]
[AM/PM], [24 Hour]
Specify this item if you want to change the time display to the 12-hour display or 24-hour display.
[Time]
00:00:00 AM/PM to 12:00:00 PM to 11:59:59 AM/PM
00:00:00 to 12:00 to 23:59:59
[Daylight Savings]*
[DST Settings]
[Off], [On]
Specifies whether to set the daylight saving time.
[Start Date/Time]/[End Date/Time]
[Month], [Week], [Day], [Time]
Specifies the time duration of the daylight saving time.
[Time Zone]*
GMT-12:00 to GMT+12:00
Specifies the time zone according to the region where the printer is being used.
[SD Card]*1*2
[Off], [On]
Specify whether to use SD cards. When the optional SD card is installed, you will be able to use the following functions.
Interrupt print
Changing the order of print data (Priority print)
Pausing/Resuming print data processing (Pausing/Resuming printing)
Saving print data on the SD card (boxes) (Stored job print)
Spooler
SMB print
Importing and Exporting Settings
Stored Job List
Print History List (Stored Job)
[Interrupt Print]*2
[Off], [On]
Set whether to allow the job printing to be interrupted.
[Sec. Print Del. Time]*1 *2
[1 hour], [2 hours], [3 hours], [6 hours], [12 hours], [24 hours]
Set the amount of time before secure print jobs are automatically deleted.
[Secure Job Log]*1*2
[Off], [On]
If [On] is specified for this item, the print log of the job being printed is saved, and the total number of printed pages (page counter) is counted even when you turn the printer OFF.
[Select PDL (PnP)]*1
[UFR II], [UFR II XPS]*2, [PCL5c], [PCL6], [PS3], [XPS (Direct)]
If you want to connect the printer and computer with a USB cable
The printer driver for this printer may be installed automatically when the USB cable is connected.
You can select the type of the printer driver ("UFR II", "UFR II XPS", "PCL5c", "PCL6", "PS3", or "XPS (Direct)") to be installed in this item at the time.
If you want to connect the printer and computer with a LAN cable
If you are using Windows Vista, you can detect the printer automatically using the WSD (Web Service on Devices) protocol.
You can select the type of the printer driver ("UFR II", "UFR II XPS", "PCL5c", "PCL6", "PS3", or "XPS (Direct)") to be installed on the automatically detected printer in this item.
[Mng. Settings]
[Settings Key Lock]
[Off], [On]
When you set to [On], [
] ( Settings) is locked and you cannot operate the Setup menu.When you set to [Off], [Settings Key Lock] is not locked.
[Adjust Screen]
[Contrast]
-3 to 0 to +3
If the display is not clear, adjust the contrast or brightness to the desired level.
[Backlight Brightness]
[Off], [Level 1], [Level 2], [Level 3]
[Animated Instruction]
[Off], [On]
Specifies whether the printer should display an animated picture in the display when a paper jam occurs or when a toner cartridge is replaced.
[Show Toner Gauge]
[Off], [On]
Specifies whether the printer should display the icon that indicates the toner remaining.
[Off], [1 second], [2 seconds], [3 seconds]
Specifies the display time of messages that are displayed when the setting completes. If [Off] is specified, no setting completion message is displayed.
[Scrolling Speed]
[Slow], [Normal], [Fast]
Set the scrolling speed for the message display on the control panel.
