[Protocol] is displayed when [IP Mode] is set to [Auto].
Settings) displays the common Setup menu.
indicates that the procedure is performed by pressing [
] or [
] on the control panel.
indicates that the procedure is performed by pressing [OK] on the control panel.|
After setting the IP address
To enable the settings, perform a hard reset or restart the printer.
For details on a hard reset, see "Canceling All the Jobs (Hard Reset)." To go back up the hierarchy
Press [
] ( Back). About the control panel
For details on the control panel, see "Control Panel."
Settings), select [Network] using [
] and [
], and then press [OK].
You can specify the settings when the printer is either online (the
Online indicator is on) or offline (the Online indicator is off). |
] and [
] and [
], and then press [OK].|
(1)
After selecting [IPv4] using [
] or [ ], press [OK]. |
(2)
After selecting [On] using [
(1):
Select [IP Mode] using [
] and [ ], and then press [OK]. |
(2):
Select a method for setting the IP address using [
Select [Protocol] using [
Select [On] for the option to be used when setting the IP address.
Set the IP address, the subnet mask, and the gateway address manually as needed.
When setting them manually, go back up the hierarchy by pressing [
] ( Back), and then perform the procedure in "If You Selected [Manual] in Step 5."
4.
Proceed to Step 7.
Select [IP Address Settings] using [
Select [IP Address], [Subnet Mask] and [Gateway Address] using [
] and [ ], press [OK]. |
[IP Address], [Subnet Mask] and [Gateway Address] are each set.
4.
Proceed to Step 7.
