Set the IP address using the control panel while checking the display on the printer.
Set the IP address using the ARP/PING command in Command Prompt.
Set the IP address using NetSpot Device Installer in the supplied CD-ROM.
When setting the IP Address using the ARP/PING command or NetSpot Device Installer
The MAC address of the printer is required. For details on the procedure for checking the MAC address, see "Checking the MAC Address."
Before setting the IP address
Make sure that the printer is connected to the network and the printer is ON.
If you changed the IP address after installing the printer driver
Specify the port to be used again in the printer driver.
