Loading Paper into the Document Insertion Unit-N1 (Optional)
The location of the Document Insertion Unit-N1 is indicated in the following illustration.
Follow the procedure below to load the paper into the Document Insertion Unit-N1.
CAUTION
When loading paper, take care not to cut your hands on the edges of the paper.
The Document Insertion Unit-N1 is an optional product.
For information on paper that can be loaded, see "Available Paper Stock."
Adjust the slide guides to fit the paper size.
To use the upper tray:
To use the lower tray:
Adjust the slide guide.
Open the tray cover.
Prepare the paper to load.
Open the packaging for the paper, and remove the paper stack.
For high-quality printouts, use paper recommended by Canon.
Before loading paper, always fan the sheets several times, and align the edges to facilitate feeding. Also, you should always fan paper that has just been removed from a newly opened paper package.
Load the paper stack into the Document Insertion Unit-N1.
If you want to load paper into the upper tray:
If you want to load paper into the lower tray:
Load the paper face up.
Load the paper face up, and close the tray cover.
4.
Select the desired paper type → press [Next].
Select the same paper type that is loaded in the Document Insertion Unit-N1.
5.
Select the desired paper size → press [OK].
Select the same paper size that is loaded in the Document Insertion Unit-N1.
To select an A or B series paper size, press [A/B Size].
Make sure that the height of the paper stack does not exceed the loading limit mark ().
You cannot make copies or prints on paper that is loaded in the Document Insertion Unit-N1.
A maximum of 200 sheets of paper (20 lb bond (80 g/m2)) can be loaded in the tray of Document Insertion Unit-N1.
For instructions on loading tab paper into the Document Insertion Unit-N1, see "Loading Tab Paper."
Rewrap any remaining paper in its original package, and store it in a dry place, away from direct sunlight.
» Maintenance » Loading Paper » Loading Paper into the Document Insertion Unit-N1 (Optional)
0S9Y-086
