Available Paper Stock
The paper types that can be used with this machine are shown in the following table. Icons indicating the type of paper loaded in each paper drawer can be displayed on the paper selection screen if you store that information in the machine beforehand. (See "Registering the Paper Size and Type for a Paper Source.")
For high-quality copies and printouts, use paper that is recommended for this machine. Using other types of paper may cause problems such as paper jams.
If you use the type of paper that is not recommended for this machine, contact your local authorized Canon dealer.
You can use various types of paper for this machine, however, you may not be able to get the sufficient image quality and paper feeding depending on the paper characteristics (stiffness, thickness, air permeability, smoothness, moisture absorbency, etc.). For the paper thickness for plain paper, for example, please use paper with thickness of 420 micrometer or less as a reference.
: Available -: Unavailable
Paper Type
Paper Source
Paper Deck of the Main Unit
POD Deck-D1/Secondary POD Deck-D1
POD Deck Lite-C1
LONG SHEET TRAY-A1
Document Insertion Unit-N1
Thin 2
(16 lb bond (60 g/m2 to 63 g/m2))
Thin 1
(17 lb bond to 20 lb bond (64 g/m2 to 79 g/m2))
Plain
(20 lb bond to 28 lb bond (80 g/m2 to 105 g/m2))
Recycled 1
Recycled 2
Recycled 3
(78 lb cover to 95 lb cover (210 g/m2 to 256 g/m2))
Color
Heavy 1
(29 lb bond to 34 lb bond (106 g/m2 to 128 g/m2))
Heavy 2
(35 lb bond to 40 lb bond (129 g/m2 to 150 g/m2))
Heavy 3
(56 lb cover to 66 lb cover (151 g/m2 to 180 g/m2))
Heavy 4
(67 lb cover to 77 lb cover (181 g/m2 to 209 g/m2))
Heavy 5
Heavy 6
(95 lb cover to 110 lb cover (257 g/m2 to 300 g/m2))
Heavy 7
(111 lb cover to 120 lb cover (301 g/m2 to 325 g/m2))
Heavy 8
(121 lb cover to 129 lb cover (326 g/m2 to 350 g/m2))
1-Sided Coated Thin
(19 lb bond to 20 lb bond (70 g/m2 to 79 g/m2))
1-Sided Coated 1
1-Sided Coated 2
(28 lb bond to 34 lb bond (106 g/m2 to 128 g/m2))
1-Sided Coated 3
1-Sided Coated 4
1-Sided Coated 5
1-Sided Coated 6
1-Sided Coated 7
1-Sided Coated 8
1-Sided Coated 9
2-Sided Coated Thin
2-Sided Coated 1
2-Sided Coated 2
2-Sided Coated 3
2-Sided Coated 4
2-Sided Coated 5
2-Sided Coated 6
2-Sided Coated 7
2-Sided Coated 8
2-Sided Coated 9
Matte Coated Thin
Matte Coated 1
Matte Coated 2
Matte Coated 3
Matte Coated 4
Matte Coated 5
Matte Coated 6
Matte Coated 7
Matte Coated 8
Matte Coated 9
Textured 1
Textured 2
Textured 3
Textured 4
Textured 5
Textured 6
Textured 7
Vellum 1*1
Vellum 2*1
Transparency*2
Translucent Film
Clear Film
Pre-Punched 1
Pre-Punched 2
Tab 1
*3
*3
Tab 2
*3
*3
Labels
Bond
*1 Some types of vellums cannot be used.
*2 Use only LTR or LTRR transparencies recommended for this machine.
*3 The Tab Feeding Attachment-E1 is required.
Paper Size
Width x Length
Paper Source
POD Deck Lite-C1
LONG SHEET TRAY-A1
13" x 19"
13" x 19"
12" x 18"
12" x 18"
12 5/8" x 17 11/16"
12 5/8" x 17 11/16"
11" x 17"
11" x 17"
LGL
8 1/2" x 14"
LTR
11" x 8 1/2"
LTRR
8 1/2" x 11"
STMTR
5 1/2" x 8 1/2"
EXEC
7 1/4" x 10 1/2"
Custom Size*1
7 1/8" x 7 1/8" to 13" x 19 1/4" (182 mm x 182 mm to 330.2 mm x 487.7 mm)
*2
Custom Size (when selecting [Long Sheet Tray])
8 1/4" x 19 1/4" to 13" x 30" (210.0 mm x 487.8 mm to 330.2 mm x 762 mm)
*1 If the Finisher-AN1/Saddle Finisher-AN2 is attached, custom paper sizes which are smaller than 13" x 19 1/4" (330.2 mm x 487.7 mm) can be output.
*2 Custom paper sizes can only be fed if they are between 5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182 mm to 330.2 mm x 487.7 mm).
Use paper soon after it is unpacked as the moisture absorption condition of paper may affect the image quality and paper feeding. Wrap any remaining paper in its original package and store it on a flat surface.
When it is necessary to perform post-processing on a translucent film, set [Color] for the paper set in the registered user settings to [Translucent (Finishing OK)]. Note that, depending on the condition of the translucent film, it may be judged as a transparent film, causing a paper jam. (See "Changing the Color.")
For instructions on loading paper, see the following sections:
The LONG SHEET TRAY-A1, POD Deck Lite-C1, POD Deck-D1/Secondary POD Deck-D1, and Document Insertion Unit-N1 are optional.
Chlorine-free paper can be used with this machine.
Storing Printouts
When handling or storing paper printed by this machine, be careful of the following points.
How to store printouts
Store paper on a flat surface.
Avoid storing printouts in folders made of PVC material, as this may cause the toner to melt and stick to the PVC material. Toner may peel when printouts are folded or creased.
Store printouts in the condition where they are not folded or creased as toner may peel.
Put printouts in a binder when storing for a long period of time (two years or longer).
Printouts may discolor when stored for a long period of time.
Avoid storing printouts in a location subject to high temperatures.
Precautions when sticking printouts with adhesive
Be sure to use insoluble adhesive.
Test the adhesive on an unneeded printout before using.
Before stacking printouts that stuck with adhesive, check that the adhesive completely dried.
» Basic Operations » Available Paper Stock
0S9Y-01H
