Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
For more information on the available paper for each paper sources, see "Available Paper Stock."
For more information on how to load paper, see "Loading Paper."
: Right Paper Drawer
: Left Paper Drawer
: POD Deck Lite-C1
: Left Paper Drawer
: Upper Paper Deck of the POD Deck-D1
: Middle Paper Deck of the POD Deck-D1
: Lower Paper deck of the POD Deck-D1
: Upper Paper Deck of the Secondary POD Deck-D1
: Middle Paper Deck of the Secondary POD Deck-D1
: Lower Paper Deck of the Secondary POD Deck-D1
Simple Settings Screen
Detailed Settings Screen
You can register paper types if paper types for the loaded paper are not displayed on the detailed setting list. For instructions on registering paper types, see "Overview of This Function."
While you are registering the custom paper type for a paper source, the paper type settings are protected and you cannot change the detailed information for custom paper type or delete the custom paper type in [Paper Type Management Settings] in [Preferences] (Settings/Registration).
To select an inch paper size, press [Inch Size].
You can select a button ([S1] to [S5]) containing a stored paper size setting, instead of entering values.
You can also specify the paper type from the Status Monitor/Cancel screen. (See "Checking the Status of Consumables and Other Information.")
