<License/Other>
You can register licenses and configure the settings related to the software and system options available for the machine.
<Register License>
<Management Settings>
<License/Other>
Enter the license key for a system option that can be used on the machine.
Installing System Options
<Print System Information>
<License/Other>
<MEAP Settings>
You can print information for MEAP applications and certain system applications as a report.
Printing List of Setting Items
<Use TLS>
<License/Other>
<MEAP Settings>
Select whether to use TLS communication when a MEAP application is used by accessing the machine via a Web browser.
Changes made for this setting are also applied to <Use TLS> in <Remote UI>.
<Confirm TLS Certificate Using MEAP Application>
<License/Other>
<MEAP Settings>
Select whether to verify TLS server certificates and their common names (CN) when TLS communication is used for a MEAP application.
<Remote UI>
<License/Other>
Select whether to use the Remote UI to operate the machine and change settings.
<Delete Message Board Contents>
<License/Other>
Select to delete messages from the administrator that are displayed on the control panel.
When <OK> is displayed on a message board, press <OK> to operate the machine. To clear a message board without <OK> displayed, you need to use the Remote UI.
<Remote Operation Settings>
<License/Other>
Select whether to enable the Remote Operation function. This function enables you to specify settings and process jobs from a computer by displaying the screen of the touch panel display on the computer screen.
<Use ACCESS MANAGEMENT SYSTEM>
<License/Other>
Select whether to use ACCESS MANAGEMENT SYSTEM.
Using ACCESS MANAGEMENT SYSTEM
<Register/Update Software>
<License/Other>
You can install system options/MEAP applications in the machine.
<Start Setup Guide>
<License/Other>
You can follow the wizard instructions to configure the machine's initial settings.
Setting up Using the Setup Guide
<Allow Use of Print Function from Mobile>
<License/Other>
If this setting is set to <On>, you can perform operations from a mobile device for documents stored in <Print> on the Main Menu.
