Saving Documents in the Advanced Box
Follow the procedures below to save scanned documents in the Advanced Box. You can use this convenient method when you want to digitize many documents so that you can share the information with the staff in a department in a paperless environment.
1
Set the original. Placing Documents
2
Press <Scan and Store> on the Main Menu. <Main Menu> Screen
3
Press <Advanced Box>.
4
Press <Shared Space> or <Personal Space>.
For information on the items on the screen and instructions on how to use them, see Working with Files and Folders in the Advanced Box.
5
Display the save location and press <Scan>.
6
Specify the scan settings as necessary.
For scan settings, see Setting Screen and Operations for Scanning to Save.
7
Press .
Originals are scanned and saved as files.
To cancel scanning, press <Cancel> or   <Yes>.
When <Press the [Start] key to scan the next original.> is displayed
To check the result of saving, press   <Store>  <Job Log>. If <NG> is displayed, the file is not saved successfully. Try the operation again.
13WR-08F
