Restricting Printing from a Computer
You can restrict printing from a computer (Printing From a Computer) so that only specific types of documents can be printed. You can also configure the machine so that documents are not printed until the user is authorized on the machine (Printing Documents Retained in the Machine (Forced Hold Printing)). You can also restrict the machine to only print Encrypted Secure Print (Printing More Safely with Encrypted Secure Print) documents, which can prevent information leakage due to unattended printouts or unprotected print data. Administrator or DeviceAdmin privileges are required in order to configure these settings.
Prohibiting Printing from a Computer
You can prohibit users from printing documents from a computer. However, even when printing from a computer is prohibited, you can allow users to save documents in the temporary storage space of the machine (Mail Box), as well as print documents saved in the Mail Box.
  <Function Settings>  <Printer>  <Restrict Printer Jobs>  <On>  Select the restriction exceptions  <OK>
Configuring the Forced Hold Printing Settings
When printing documents from a computer, you can hold print data in the machine and prevent documents from being printed immediately (Printing Documents Retained in the Machine (Forced Hold Printing)). You can configure settings so that printing cannot be performed until the user is authorized on the machine, which ensures greater security and reduces the risk of other people viewing or inadvertently picking up sensitive documents. Administrator privileges are required in order to configure these settings.
1
Press .
2
Press <Function Settings>  <Print>  <Forced Hold>.
3
Press <On>, set the necessary conditions, and then press <OK>.
You can set detailed conditions for holding printer jobs, such as the user or IP address. If no conditions are set, all print jobs are held except for jobs from unidentified users. If no conditions are set and a print job from an unidentified user is received, it is canceled without being held.
Setting the conditions for holding documents
4
Press     <Apply Set. Changes>  <Yes>.
Configuring the detailed settings for forced hold printing
You can configure detailed settings for documents that are held for printing, such as how long to save them and how to display them. <Forced Hold>
Allowing Only Encrypted Secure Print
You can configure the machine to only allow printing of Encrypted Secure Print documents from a computer, which can prevent information leakage due to unprotected print data. With this setting, documents cannot be printed using normal printing operations. Users are required to enter a password on the machine when printing Encrypted Secure Print documents. Printing Documents Retained in the Machine (Forced Hold Printing)
  <Function Settings>  <Print>  <Only Allow Encrypted Print Jobs>  <On>  <OK>      <Apply Set. Changes>  <Yes>
13WR-0C6
