      0WR7-0UH
      <Timer/Energy Settings>
      This section describes the timer settings and energy settings.
      Item
      Description
      <Adjust Time>
      You can adjust the time in minutes
      Setting Value
      NOTE:
      Even if you change the time from 23:59 to 00:00, the date will not be changed.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Date/Time Settings>
      Setting the current date and time is very important. The current date and time settings are used as standard timer settings for functions that require them. For instructions on how to configure the setting, see Setting the Date/Time.
      Setting Value
      <Time Zone>: <UTC-12:00> to <UTC+12:00>
      <Daylight Saving Time>: <On>, <Off>, <Start Date> (→), <End Date> (→)
      Current date/time: Specify the current date/time.
      <Start Date>: Specify <Month>, <Day>, <Time>.
      <End Date>: Specify <Month>, <Day>, <Time>.
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      <Time Format>
      You can set whether to display the time in 24-hour notation or 12-hour notation.
      Setting Value
      <24 Hour>, <12 Hour>
      DeviceAdmin: No
      NetworkAdmin: No
      <Quick Startup Settings for Main Power>
      If you set the quick startup, you can reduce the time from turning ON the machine to starting operating the machine and scanning documents. If this setting is ON, the standby power is generated even when the machine is turned OFF. Do not pull out the power cable when this function is used. Depending on the status of the machine, quick startup cannot be performed.
      Setting Value
      <On>, <Off>
      NOTE:
      If you set quick startup, a tone sounds when turning On/Off the machine. (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
      DeviceAdmin: No
      NetworkAdmin: No
      <Auto Reset Time>
      You can specify the time period in which you are logged out and the touch panel display returns to the default setting automatically.
      Setting Value
      0=Off/10, 20, 30, 40, 50 sec./1, 2 to 9 min.
      NOTE:
      If you select <0>, the Auto Reset Time is not set.
      If the Auto Reset Time elapses when using a login service, the display returns to the screen for entering the user name and password.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Device Information Distribution Available: Yes
      <Restrict Auto Reset Time>
      If you set this function to <On>, general users become unable to use the <Auto Reset Time> and <Function After Auto Reset>.
      Setting Value
      <On>, <Off>
      NOTE:
      You can specify the time of auto reset.
      DeviceAdmin: No
      NetworkAdmin: No
      You can set whether the default screen set for <Default Screen after Startup/Restoration> in <Preferences> is displayed at startup after the Auto Reset initiates.
      Setting Value
      <Initial Function>: The display returns to the screen set for <Default Screen after Startup/Restoration> after the Auto Reset initiates.
      <Selected Function>: The display returns to the initial screen of the function currently used after the Auto Reset initiates.
      NOTE:
      You can set the period of idle time required for the Auto Reset mode to initiate.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Auto Sleep Time>
      If the machine is idle for a certain period of time (after the last print job or key operation is performed), the machine automatically enters the Energy Saver mode or Sleep mode to save power. For instructions on how to select the mode, see <Timer/Energy Settings>  <Mode After Energy Saver Key Pressed>.
      Setting Value
      10 sec./1, 2, 10, 15, 20, 30, 40, 50 min./1 hr./90 min./2, 3, 4 hr.
      DeviceAdmin: No
      NetworkAdmin: No
      <Sleep Mode Energy Use>
      You can set the amount of energy that the machine consumes when it is in the Sleep mode.
      IMPORTANT:
      If the machine is connected to a computer using a USB cable, depending on the timing for entering the sleep mode, the machine may be unable to receive data correctly. Reactivate the machine from the sleep mode, then execute the job again.
      The energy consumption level is <High> even when set to <Low>, depending on the status of the machine.
      Setting Value
      <Low>, <High>, <Compensate for Network Comm.>
      NOTE:
      If you want to perform the wireless communication during sleep mode, select <Compensate for Network Comm.>.
      If the energy consumption level is set to <Low>, communication failure may occur, depending on the network utility software you are using. To avoid this, press key to cancel the Sleep mode before using the machine.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Auto Sleep Weekly Timer>
      You can set the time that the machine automatically enters the Sleep mode each day of the week.
      Setting Value
      <Sunday> to <Saturday>: Enter the time.
      NOTE:
      If you set both the <Auto Sleep Time> and <Auto Sleep Weekly Timer>, the <Auto Sleep Time> setting is given priority.
      DeviceAdmin: No
      NetworkAdmin: No
      <Energy Saver/Sleep Mode Exit Time Settings>
      You can set the time that the machine automatically exits the Sleep mode each day of the week.
      Setting Value
      Enter the time.
      DeviceAdmin: No
      NetworkAdmin: No
      You can select the mode which is activated after the Energy Saver key is pressed. In <Energy Saver Mode>, the machine consumes more power than in <Sleep Mode>, but operations can be resumed more quickly.
      Setting Value
      <Energy Saver Mode>, <Sleep Mode>
      DeviceAdmin: No
      NetworkAdmin: No
      <Change Energy Saver Mode>
      When the machine is not used for a prolonged period of time, you can set the machine to enter the Energy Saver mode by pressing  on the control panel. The Energy Saver mode conserves energy by lowering the temperature of the fixing unit. To reactivate the machine, press  again.
      IMPORTANT:
      Setting <Mode After Energy Saver Key Pressed> in <Energy Saver Mode> is required to set energy saver mode .
      Setting Value
      <‐10%>, <‐25%>, <‐50%>, <Zero Restore Time>
      NOTE:
      After deactivating the Energy Saver mode, the machine's recovery time may vary, depending on the energy saving level setting and the surrounding environment (i.e., temperature, humidity, etc.).
      DeviceAdmin: No
      NetworkAdmin: No
      <Silent Mode Time>
      This machine enters the Silent mode after a specified time period has elapsed following a print job, or a key operation is performed. You can specify the time period until the machine automatically enters the Silent mode.
      Setting Value
      0=Off/1 to 9 min.
      NOTE:
      If <0> is selected, the Silent mode is not set.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Sleep Mode Eco Exit>
      When you cancel sleep mode and start the operation, you can activate necessary functions sequentially. The control panel is activated first, followed by other functions activated in response to the user's operations. You can save energy and lower noise by not activating unnecessary functions.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Use Motion Sensor>
      When the motion sensor detects a person near the machine, the machine exits sleep mode automatically. Select the sensitivity of the sensor considering the machine's wake-up speed and false detection.
      Setting Value
      <On>:
      <Sensor Sensitivity>:
      <Low>: The machine exits sleep mode slower than <Medium>. Select this mode if you want to avoid false detection.
      <Medium>: The machine exits sleep mode faster than <Low>.
      <High>: The machine exits sleep mode faster than <Medium>. Select this mode if you want more sensitive detection.
      <Off>
      NOTE:
      When the room temperature is high or users' body temperatures are low, detection becomes difficult. In this case, set <Sensor Sensitivity> to <High>.
      If temperature varies around the machine, detection may become too sensitive and exit sleep mode easily. In this case, set <Sensor Sensitivity> to <Low>.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
