      0WR7-0J5
      <Network Settings>
      You can specify the settngs to access the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server from the machine.
      Item
      Description
      <Network Place Settings>
      You can register the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server as an external reference. Connecting to the Other Devices
      IMPORTANT:
      Do not register something other than the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server which is opened externally, as this may cause the machine to malfunction.
      Setting Value
      <Register> (→), <Edit> (→), <Details>, <Delete>
      <Register>, <Edit>
      <Name>
      <Protocol>: <SMB>, <WebDAV>
      When <SMB> is selected
      <Location>
      When <WebDAV> is selected
      <Host Name>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Protocol for External Reference>
      You can select the protocol to use when accessing the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server which is opened externally.
      Setting Value
      <SMB>: <On>, <Off>
      <WebDAV>: <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Confirm TLS Certificate for Network Access>
      You can confirm whether the TLS server certificate is valid when accessing the Advanced Box of another imageRUNNER ADVANCE series machine or a Windows server. You can verify the validity of the certificate and reliability of the certificate chain, as well as confirm the CN (Common Name).
      IMPORTANT:
      If you do not verify the certificate, TLS communication is performed, even with an invalid certificate.
      Setting Value
      <On>, <Off>
      When <On> is selected
      <CN> for <Add Items to Verify>: Enabled, Disabled
      DeviceAdmin: No
      NetworkAdmin: No
