To connect the machine to the storage spaces on other multifunction printers, settings of the other printers are also necessary. Setting Advanced Box to Public
1
Press <Network Place Settings>
2
Enter the necessary information and press <OK>.
![]() ![]() Enter the name of the Advanced Box to connect to. As a name entered here is displayed on the list at the time of access, enter a name that is easy to read.
![]() Select <SMB> or <WebDAV>, depending on whether the Windows server or Advanced Box of destination is made available as an SMB server or WebDAV.
![]() <Location> is displayed when you select <SMB>, and <Host Name>is displayed when you select <WebDAV> in the protocol setting.
Enter the address in <Location> as "\\ (host name or IP address) \share" to connect to a shared space, or "\\ (host name or IP address) \users" to connect to personal space.
Enter the address in <Host Name> as "https:// (host name or IP address)", and press <Next>. Then, enter "/share" for the shared space or "/users" for the personal space in <Folder Path>.
1
Press <Protocol for External Reference>.
2
Press <On> of the protocol you use, then press <OK>.
IMPORTANT:
When connection via SMB is not used, set the <SMB> setting to <Off>. When connection via WebDAV is not used, set the <WebDAV> setting to <Off>.
1
Press <Confirm TLS Certificate for Network Access>.
2
Press <On>
![]() When you press <On>, the screen for adding the verification items is displayed. If you need to verify the CN (Common Name), add a check mark.
