Item
Description
<Register/Edit Favorite Settings>
You can register frequently used settings in a button of the machine for later use when saving. You can also assign your favorite name to a button and check registered settings.
Setting Value
Buttons where settings are to be registered: <M1> to <M9>
<Register>, <Rename> (→), <Delete>, <Check Content> (→) <Rename>: Change a button name.
<Check Content>: Check the registered settings.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
<Change Default Settings>
You can change and register some scan settings of <Scan and Store> on the Main Menu as default settings.
Setting Value
<Register>, <Initialize>
DeviceAdmin: Yes
