      0WR7-0HX
      <Common Settings>
      You can specify the common settings to use when storing scanned documents or using stored files.
      Item
      Description
      You can register/change the settings to use when saving documents from <Scan and Store> on the Main Menu.
      You can register/change the settings to use when printing documents from <Access Stored Files> on the Main Menu.
      <Limit Box PIN to 7 Digits/Restrict Access>
      The password used for the Mail Box can be set using at least one digit. Selecting <On> requires a seven-digit password for the Mail Box, enhancing a security.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
