      0WR7-0HJ
      <Remote Fax TX Settings>
      You can specify the settings so that the machine can be used as a client machine for the Remote Fax function.
      Item
      Description
      <Remote Fax Server Address>
      You can specify the IP address or the host name of a Remote Fax server machine.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <TX Timeout>
      You can set the TX timeout. When a Remote Fax server does not respond within the specified time, the machine stops trying to send remote faxes.
      Setting Value
      1 to 24 to 99 hr.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <No. of TX Lines>
      You can set the number of lines you can select when sending remote faxes. Set the number of lines to the same number of telephone lines connected to the Remote Fax server.
      Setting Value
      1 to 4 Line
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Select Priority Line>
      You can specify the line to use when sending remote faxes.
      Setting Value
      <Auto>, <Line 1>, <Line 2>, <Line 3>, <Line 4>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Use IP Fax>
      You can select whether to use IP faxes.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <IP Fax Communication Mode Settings>
      You can specify the communication mode to use when sending IP faxes.
      Setting Value
      <Use Intranet>: <On>, <Off>
      <Use VoIP Gateway>: <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
