      0WR7-0HF
      <Line 1>
      You can specify settings for line 1.
      Item
      Description
      <Register Unit Telephone Number>
      You can register the fax number to use when the fax is used on the machine. The registered fax number is printed on paper at the recipient as the sender information when you send a fax.
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Register Unit Name>
      You can register the name of your company or department as the unit name. The registered name is printed on paper at the recipient as the sender information when you send a fax.
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Select Line Type>
      You can set the type of telephone line connected to the machine. If this setting is incorrect, you will be unable to communicate with other machines. Be sure to check the type of telephone line that you are using, and make the correct setting.
      Setting Value
      <Pulse>, <Tone>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Edit Line Name for Select Line Screen>
      You can register the line name of a button displayed on the <Select Line> screen.
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: No
      <Default Address List When Selecting Line>
      You can specify the type of address list that you want to display as the default setting when you use the Address Book on the Fax Basic Features screen. This setting is only effective when you select the line to use on the <Select Line> screen.
      Setting Value
      <Address List 1> to <Address List 10>, <Address List for Admin.>, <All Address Lists>
      DeviceAdmin: Yes
      NetworkAdmin: No
