Restricting the Fax Sending Functions
You can set various restrictions for sending faxes, which can prevent sending errors and information leakage to third parties. Administrator privileges are required in order to configure these settings.
Confirming Fax Numbers before Sending
You can require users to enter a fax number twice for confirmation before sending faxes, to prevent misdialing. This setting can also be configured with DeviceAdmin privileges.
<Function Settings>
<Send>
<Fax Settings>
<Confirm Entered Fax Number>
<On>
<OK>
Restricting Fax Sending from a Computer
<Function Settings>
<Send>
<Fax Settings>
<Allow Fax Driver TX>
<Off>
<OK>
Displaying a Confirmation Screen for Fax Destinations
You can set the machine to display a confirmation screen when sending to a fax destination. This can help prevent fax sending errors.
When the function for confirming the fax number before sending ( Confirming Fax Numbers before Sending) is enabled, the confirmation screen is not displayed if there is only one destination.
Restricting Sequential Broadcasting
You can restrict the sequential broadcasting function, which enables users to send a fax to multiple recipients in succession.
LINKS
