Lift the release lever.
Turn the dial counterclockwise, and remove the jammed document.
The jammed document moves to the document output tray.
Lower the release lever.
Open the feeder.
Remove the jammed document.
Gently close the feeder.
When multiple sheets are fed
Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Copy/Fax/Scan Basic Features screen
