If you select <Large 2 Count Management> on the <Page Totals> screen, each side of scanned 11" x 17" size paper is counted as two pages, and both sides of scanned 11" x 17" size paper is counted as four pages.
If you print via a printer driver that does not support Department ID, Department ID is not displayed.
If "NG" is displayed in the printed list, printing, communicating, or saving scanned documents may have failed. Check the three-digit number preceded by "#" in the printed list to find the reason and solutions. When a Number Preceded by "#" (Error Code) Appears
If you press
1
Press <Copy/Print>
2
Select the item you want to print, and press <Print List>.
3
Press <Yes>.
1
Press <Send> or <Receive>
2
Select <Send> or <Receive> from the drop-down list, and press <Communic. Mgt. Report>.
3
Press <Start Printing>.
For documents sent by e-mail, the list indicates the sending results between the machine and the mail server, not between the machine and the destination.
If you select <Output Spec. No. of Transm.> in step 3, you can specify the number of log results that appear in the list.
You can specify whether or not to print the list automatically. Communication Management Report
1
2
Select <Fax> from the drop-down list, and press <Fax Activity Report>.
3
You can specify whether or not to print the list automatically. Fax Activity Report
1
Press <Store>
2
Press <Yes>.
If you press
You cannot configure the settings for the Communication Management Report while <Display Job Log> in <Management Settings> is <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Auto Print (100 Transmissions)> and <Specify Print Time> in the Communication Management Report automatically changes to <Off>. <Device Management>
For documents sent by e-mail, the report indicates the sending results between the machine and the mail server, not between the machine and the destination.
You can manually print a Communication Management Report from a list in the usage history. Sending/receiving log
When setting to print a report at a specified time
If a report is set to print at a specified time, the 100 most recent results are printed, with the most recent results first. If the number of results exceeds 100, the older results are not printed.
Even if you set <On> in <Report with TX Image> in the report setting, the sent message is not displayed in a report when an encrypted PDF is sent.
You cannot configure the settings for the Fax Activity Report while <Display Job Log> in <Management Settings> is <Off>. In addition, if you change <Display Job Log> in <Management Settings> from <Off> to <On>, <Auto Print (40 Transmissions)> and <Specify Print Time> in the Fax Activity Report automatically changes to <Off>. <Device Management>
You can manually print a Fax Activity Report from a list in the usage history. Fax sending/receiving log
If a report is set to print at a specified time, the 40 most recent results are printed, with the most recent results first. If the number of results exceeds 40, the older results are not printed.
A Multi TX Report is printed when <Fax TX Report> is set to <On> and broadcast transmission is performed.
Even if you set <Report with TX Image> to <On> in the report setting, the sent message is not displayed when you send a fax directly to the recipient's machine using Direct Sending Checking the Connection to the Recipient Before Sending (Direct Send) or Manual Sending Sending Faxes Manually (Manual Sending).
Even though <Off> is set in this setting, if Fax RX Report is enabled, a report is printed when a fax is saved in the Confidential Fax Inbox.
When you are logged in with Administrator privileges, you can manually print the device information communication history as a list. Press
![]() ![]() ![]() ![]() ![]() ![]() ![]() When setting to print a report at a specified time
