<Paper Settings>
<Multi-Purpose Tray Defaults>.
<Register>.
1
Select the standard size paper.
2
Press <Next>.
1
Press <Custom Size>.
![]() You can specify the paper size as <Free Size>, which eliminates the need to enter the paper size setting. Specify <Free Size> when you load paper of unknown size to use for copying or when the paper size is already registered in the printer driver.
2
Specify the length of the <X> side and <Y> side.
![]() Press <X> or <Y> to enter the length of each side using the numeric keys.
![]() If you register the paper size you use frequently on buttons <S1> to <S5>, you can call them up with one touch. Registering Free Size Paper (Custom Size Paper)
3
Press <OK>
<Next>. |
1
Press <Envelope>.
2
Select the orientation and type of envelopes.
![]() If you changed the placement of the envelopes, press <Short Edge Feed> or <Long Edge Feed>, and select the envelope type.
If you selected vertical placement for Nagagata 3, press <Next>, and specify the flap length.
To register a custom size envelope, press <Custom Size>
<Next> and press <X> or <Y> to specify the side, then use the numeric keys to enter the length of the specified side.![]() When using Kakugata 2, place it horizontally.
3
Press <OK>
<Next>. |
