Loading Paper
The paper source to use and the paper loading method to follow vary depending on the type and size of paper you use. For more information about available paper types and sizes, see Specifications. To obtain the optimum printing results, make sure to correctly specify the size and type of paper that is loaded.
Before using any paper, confirm the precautions regarding paper and the correct way to store it. Available Paper
Loading paper while stock remains may cause a multiple sheet feed or a paper jam. If there is paper remaining, it is recommended that you wait until all of it has been used before loading more paper.
Do not load different sizes or types of paper together.
1713-025
