To successfully send faxes to the destination you intend, you can check beforehand that the recipient is connected and ready to start communication. As the machine bypasses memory when scanning originals, you can send faxes even if there is no memory available.
<Direct Send>.
Direct Send is not available in the following casesAny of the following scan settings are specified: <2-Sided Original>/<Erase Frame>/<Job Build>/<Delayed Send>
Multiple destinations are specified.
<Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
To specify the scanning size of originalsThe scanning size of originals placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
