Make sure that Department IDs have been set for the users registered in the machine. Registering User Information in the Local Device
1
Press <Register PIN>.
2
Press <Register>.
![]() To edit Department ID settings
Select the Department ID that you want to edit, and press <Edit> to display the Edit screen.
To delete Department ID settings
Select the Department ID that you want to delete, and press <Delete>
3
Enter the Department ID and PIN, and press <OK>.
![]() ![]() Enter a number of 7 digits or less for the Department ID.
![]() Enter a number of 7 digits or less for the PIN, and press <Confirm>. For confirmation, enter the PIN again and press <OK>. If you do not want to set a PIN, leave this item blank.
![]() You cannot register a Department ID or PIN consisting only of 0s, such as "00" or "0000000".
You can press <Turn Limit On/Off and Set Page Limit> to set the total number of pages that the department is allowed to use for copying, scanning, and printing.
You can also make entering seven digits a requirement for Department IDs and PINs. For more information, contact your local authorized Canon dealer.
4
Press <OK>.
To check the page countsIf you want to check the total number of pages used by each Department ID for copies, prints, and scans (including faxes), press <Page Totals> on the screen displayed in step 3. The page counts do not include blank pages or sample prints used for checking items such as gradation adjustment or secure watermarks.
