<Paper Settings>
This section describes how to register paper to use.
<Paper Settings>
<Preferences>
<Paper Settings>
You can register the paper size and type for each paper source. This setting enables you to achieve the appropriate print results.
Specifying Paper Size and Type in the Paper Drawer
<Paper Size Group for Auto Recognition in Drawer>
140K-0S1
<Preferences>
<Paper Settings>
You can set the paper size group for each paper source to make the machine detect the loaded paper size automatically.
<A5/STMT Paper Selection>
<Preferences>
<Paper Settings>
When A5 or STMT paper is loaded in the paper drawer, you can set the size to use for the operation.
<Paper Type Management Settings>
<Preferences>
<Paper Settings>
You can register/edit various customer paper types (user defined paper types), besides the default paper types registered in the machine.
Managing Paper Types
You can edit only user-registered paper types.
1
Press .
2
Press <Preferences> <Paper Settings>.
3
Press <Paper Type Management Settings> specify the settings.
Paper type drop-down list
Enables you to select the paper type to display.
 <Sort List By>
Enables you to change the display order of the list.
 <Details/Edit>
Displays details for the selected paper type on the <Details/Edit> screen. If you select a custom paper type, you can edit it.
 <Duplicate>
Duplicates the selected paper type as a custom paper type.
 <Delete>
Deletes the selected custom paper type.
 <Change>
Appears on the <Details/Edit> screen for the custom paper type and enables you to change the settings for the following items.
You can only edit/delete custom paper types.
<Name>: Change <Name> of the registered custom paper.
When you register the custom paper, make sure to change its name. You cannot change the settings of the paper types that are registered in the machine as default.
<Basis Weight>: Change <Basis Weight> of the registered custom paper.
If you enter a value that is different from the actual weight of the loaded paper, paper jams may occur, and the quality of the image may be adversely affected.
<Finish>: Change <Finish> when you register uncoated paper, recycled paper, transparencies, labels, etc. as custom paper.
If you select a finishing type which is different from that of the loaded paper, paper jams may occur, and the quality of the image may be adversely affected.
<Type>: Change <Type> when you register pre-punched paper, etc. as custom paper.
If you select a paper type which is different from that of the loaded paper, paper jams may occur, and the quality of the image may be adversely affected.
<Color>: Change <Color> of the registered custom paper.
If you select a color which is different from that of the loaded paper, paper jams may occur, and the quality of the image may be adversely affected.
4
Press <OK>.
<Register Favorite Paper (Multi-Purpose Tray)>
<Preferences>
<Paper Settings>
You can easily specify paper settings by registering paper frequently used in the multi-purpose tray in a button. "Favorite Paper" can be easily recalled from the screen displayed when paper is loaded.
Registering Frequently Used Paper Size and Type for the Multi-purpose Tray
<Multi-Purpose Tray Defaults>
<Preferences>
<Paper Settings>
Registering the default multi-purpose tray paper is convenient if you always use the same size and type of paper in the multi-purpose tray.
<Register Custom Size>
<Preferences>
<Paper Settings>
You can register frequently used free sizes of paper. The paper sizes registered here are displayed on the paper size selection screen for the paper drawer and multi-purpose tray.
Registering Free Size Paper (Custom Size Paper)
