Top » Optional Products (imageRUNNER ADVANCE C7270/C7260) » Removable HDD Kit
Removable HDD Kit
08JK-052
The Removable HDD Kit can hold hard disks. You can remove and store the hard disks in a safe place when the machine is not in use. When the HDD Mirroring Kit or HDD Data Encryption & Mirroring Kit is used with the Removable HDD Kit, you can store the same data on two hard disks and you can encrypt the data and store the hard disks in a safe place.
Parts and Their Functions
Hard Disk Holder
Holds the hard disk. To store the hard disk, place it in the hard disk holder.
Front Cover
Open this cover to set/remove the hard disk holder.
The Removable HDD Kit can be attached to the side of the machine. For information on attaching the Removable HDD Kit to the machine, contact your local authorized Canon dealer.
If the message <E602-0001> appears on the touch panel display when the machine starts, a hard disk may not be inserted in the Removable HDD Kit. Turn OFF the main power of the machine and check that the main power indicator on the control panel is not lit, and then check the Removable HDD Kit. If the error message still appears after you correctly set the hard disk, contact your local authorized Canon dealer.
