e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)
Optional Products (imageRUNNER ADVANCE C7270/C7260)
Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
Upright Control Panel-B1
Duplex Color Image Reader Unit-F1
Paper Deck Unit-C1/POD Deck Lite-A1
USB Device Port-A2
Multimedia Reader/Writer-A2
Printer Cover-B1
Staple Finisher-L1/Booklet Finisher-L1/External 2/3 Hole Puncher-A1
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1
Copy Tray-P1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Software
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Printer Cover-B1
Printer Cover-B1
08JK-04U
Instead of the Duplex Color Image Reader Unit-F1, you can attach the Printer Cover-B1. For details, contact your local authorized Canon dealer.
Parts and Their Functions
Printer Cover
Instead of the the Duplex Color Image Reader Unit-F1, you can attach the printer cover.
Back to Top
