Top » Optional Products/Software » Software » Workflow Composer
Workflow Composer
07SE-044
Workflow Composer is an option that increases the efficiency of routine operations that use multiple functions of machines. By creating and registering combinations of functions that are frequently used on the machine, you can repeatedly reuse the same combination of functions.
For example, you can scan an 11" x 17" original and reduce it to LTR size, and then send it to a customer via e-mail; all with the press of a button.
