Category Top
Optional Equipment and System Requirements
Printing or Sending a Fax from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE802.1X Authentication Settings
Selecting the IEEE802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Startup Time Settings
Setting Up a Computer for Printing/Sending a Fax
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2
Mac OS X 10.4.9 or Later
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2
Top » Network » TCP/IP Network Setup Procedures » Protocol Settings
Protocol Settings
07SE-1KR
This section describes how to specify the protocol settings for the machine using the control panel. If you are configuring the settings for the first time, use the control panel of the machine.
After configuring the settings, you can change them using software other than the control panel of the machine. For more information, see "Settings/Registration Table."
When using functions to access external servers on the internet, you may not be able to access them due to the settings of firewalls, etc. In this case, consult the administrator for the network you are using.
