Top » Maintenance » Replacing the Stamp Ink Cartridge (Feeder)
07SE-0FA
Originals sent via the feeder can be stamped to indicate that they have been sent. Replace the stamp ink cartridge when the stamp mark is faint or no longer visible.
CAUTION
When replacing the stamp ink cartridge, take care not to allow ink to come into contact with your hands or clothing. If ink gets onto your hands or clothing, wash it off immediately with cold water.
Open the covers.
1. Pull the lever → open the feeder cover.
2. Open the inner cover, holding it by its tab.
Load the stamp ink cartridge.
1. Remove the old stamp ink cartridge, using tweezers.
2. Push in the new stamp ink cartridge until it clicks, using tweezers.
Make sure that the stamp ink cartridge is not protruding from the surface.
Insert the stamp ink cartridge properly, or paper jams may occur.
Close the covers.
1. Close the inner cover.
2. Close the feeder cover.
CAUTION
When closing the covers, be careful not to get your fingers caught, as this may result in personal injury.
