Editing Forwarding Settings
08KE-0EE
You can check or change forwarding settings that have been stored.
Press
(Settings/Registration).
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [Forwarding Settings].
Checking/Changing Forwarding Settings:
Select the forwarding settings you want to check or change → press [Details/Edit].
Check or change the settings as necessary → press [OK].
Forwarding Received Files:
Select the forwarding settings → press [Validate/Invalidate].
Details of each item are shown below:
[On]:
Received files that match the forwarding conditions are forwarded to the specified destination.
[Off]:
Received files are not forwarded to the specified destination, even if they match the forwarding conditions.
To cancel this setting, press [Validate/Invalidate] again.
Deleting Forwarding Settings:
Select the forwarding settings that you want to delete → press [Delete] → [Yes].
4.
Press [Close].
