Top » Status Monitor/Cancel » Checking the Status of Consumables and Other Information
08KE-1E5
You can check the status of consumables, such as detailed paper information and the remaining amount of toner and staples, the backup status of the stored data, and the connection status of the Advanced Box. You can also register/set the paper type to load in a paper drawer.
Press (Status Monitor/Cancel).
Press [Consmbls./Others].
To check the details of paper loaded in the machine:
To check other information:
To check the connection status of the Advanced Box:
To check the backup status of the stored files:
To register/set a paper type:
Select the paper you want to check → press [Details].
You can press  to enlarge the displayed list.
Press [OK].
Check the percentage of memory usage, amount of waste toner, and the remaining amounts of toner and staples.
The table below indicates the remaining amount of consumables.
Display
Remaining amount of toner
OK
100% to 11%
Low
10% to 1%
Empty
0%
Display
Amount of waste toner
OK
0% to 95%
Near Full
96% to 99%
Full
100%
Display
Remaining amount of staples
Remaining amount of saddle stitch staples
OK
100% to 26%
Low
25% to 1%
Empty
0%
Press [Adv. Space Conn. Status].
Check the number and the IP addresses of the connected clients.
[Adv. Space Conn. Status] does not appear in the following case:
<Advanced Box/Network> in [Store Location Display Settings] in [Display Settings] in [Preferences] (Settings/Registration) is set to 'Off'.
If the Advanced Box is open to public via SMB and [Use SMB] in [Preferences] (Settings/Registrations) is set to 'On', clients connected to the SMB printer will also be displayed and counted as the connected clients. For instructions on setting the Advenced Space to open to public via SMB or WebDAV, see "Advanced Box/Network Settings."
Check the backup status of the stored files.
The table below indicates the the backup status.
Display
Stauts
Backup is available.
Processing
Backing up stored files.
For instructions on setting for backing up the stored data, see "Backing Up Stored Data."
Press [Reg.].
Select an item to register/set → register/set the paper type.
[Paper Settings]:
Sets the paper type to load by selecting a paper source.
[Paper Type Management Settings]:
Registers a user-defined paper type by entering a name.
For instructions on specifying [Paper Settings], see "Registering the Paper Size and Type for a Paper Source."
For instructions on specifying [Paper Type Management Settings], see "Registering/Editing Custom Paper Types."
Press [OK].
