: Paper that is registered from [Duplicate] with default settings.
: Paper that is registered from [Duplicate] with changed settings.|
You can edit only user-registered paper types.
You cannot change the detailed information for paper currently being used for copy/print jobs.
You can sort the paper type list by registration date ([Registered]), name ([Name]), or basis weight ([Basis Weight]) from the Sort List drop-down list.
(Settings/Registration). |
When you register the settings for the custom paper type, make sure to change its name. You cannot change the settings of the default paper types registered in the machine.
If you enter a value that is different to the actual weight of the paper, paper jams may occur, and the quality of the image may be adversely affected.
If you select a finishing type which is different from the actual surface texture of the paper, paper jams may occur, and the quality of the image may be adversely affected.
If you select a paper type which is different from the actual paper type, paper jams may occur, and the quality of the image may be adversely affected.
If you select a color which is different from the actual color of the paper, paper jams may occur, and the quality of the image may be adversely affected.
] or [
] to adjust the correction width → press [OK].|
For more information on creep (displacement), see "Booklet Mode" and "Two-Sided Printing."
The value you set here becomes the default correction width when the selected paper type is used for saddle stitching with automatic [Creep Correction].
5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182.0 mm to 330.2 mm x 487.7 mm) paper can be used for the test pages. Make sure that a sufficient supply of paper is loaded into the machine before starting this procedure.
If you perform test page using paper smaller than 11" x 17", the entire image cannot be printed on the paper. Nevertheless, you can read the register mark, because the tail edge you do not have to check is lacking.
Press when the center line of the register mark is located outside the edge of the test page (the center line of the register mark is NOT printed). The image is shifted to the backwards as seen from the feeding direction of the paper, according to the number of pixels entered.
Press when the center line of the register mark is located inside of the edge of the test print. The image is shifted to the forwards as seen from the feeding direction of the paper, according to the number of pixels entered.
Press when the center line of the register mark is located outside the edge of the test print (the center line of the register mark is NOT printed). The image is shifted to the backwards as seen from the feeding direction of the paper, according to the number of pixels entered.
When you open the [Adjust Image Position] screen again after you close that screen by pressing [OK], the values on screen are returned to [0]. Nevertheless the adjusted value is effective. If you repeat steps, read off the value of register marks from new test page and input the new value.
Press when the center line of the register mark is located outside the edge of the test print (the center line of the register mark is NOT printed). The image is shifted to the right as seen from the feeding direction of the paper, according to the number of pixels entered.
Press when the center line of the register mark is located inside of the edge of the test print. The image is shifted to the left as seen from the feeding direction of the paper, according to the number of pixels entered.
If you perform a test page using paper that is perpendicular to the feeding direction and is 12" (305.1 mm) or more in length, the A1 register marks will be printed 12.5 mm inside the left edge of the paper. From the feeding (lead) edge of the test page, take a ruler and measure 12.5 mm inside the left edge of the paper, and place a mark there. Place another mark to the right of the A1 register marks (12.5 mm inside the left edge of the paper). Draw a straight, horizontal line between the two marks you just made. Compare the line you just drew with the center line of the A1 register marks. If the two lines are askew from each other, the distance between the two lines determines how much you have to adjust the image location.
![]() *1 12.5 mm *2 Left Edge of Paper *3 12" (305.1 mm) or more In the example above, the center line of the A1 register marks and the drawn line are aligned. Therefore, you do not need to adjust the image location. When you open the [Adjust Image Position] screen again after you close that screen by pressing [OK], the values on screen are returned to [0]. Nevertheless the adjusted value is effective. If you repeat steps, read off the value of register marks from new test page and input the new value.
[a]:
Enlarges or reduces the image in the direction that is parallel to the feeding direction according to the inputted ratio.
[b]:
Enlarges or reduces the image in the direction that is perpendicular to the feeding direction according to the inputted ratio.
[a]:
Enter the measured length of the side that is parallel to the feeding direction.
[b]:
Enter the measured length of the side that is perpendicular to the feeding direction.
Printing performance may not be optimal if you use the Fine Adjustment Zoom mode.
If you perform a test page using paper smaller than 11 3/8" x 15 1/2" (287 mm x 393 mm), you will not be able to measure the length of a and b since the entire image cannot be printed on the paper. In this case, enter the expanding/reducing percentage to adjust the zoom ratio, instead of entering the actual length of a and b.
You can only delete user-registered paper types.
