Top » Remote UI » Audit Log Management
08KE-1X9
This function enables you to collect/manage the logs stored in the machine with the Remote UI. The administrator can check the collected logs to survey how the machine is being used.
Types of Logs
This function can manage the following logs:
User Authentication Log
This log contains information related to the authentication status of user authentication, and the registering/changing/deleting of user information.
Login/Logout Log
User Authentication Success/Failure Log
Log for the registering/changing of user information managed by SSO-H
Log for Role Management (adding/setting/deleting) by Access Management System
Job Log
This log contains information related to the completion of copy/fax/scan/send/print jobs.
Mail Box Document Operation Log
This log contains information related to the operations performed on data in the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Mail Box Authentication Log
This log contains information related to the authentication status of the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Advanced Box Save Log
This log contains information related to the saving files to the Advanced Box, the Network (Advanced Box of other machines), and the Memory Media.
Advanced Box Operation Log
This log contains information related to the operations performed on file to the Advanced Box, the Network (Advanced Box of other machines), and the Memory Media.
Network Connection Log
This log contains information regarded to IPSec communication failures.
Machine Management Log
This log contains information related to the starting/shutting down of the machine and the following management operations:
When (Settings/Registration) is pressed to change the machine settings
When the Device Information Delivery Settings mode is used to change the machine settings
When the time of the machine is set/changed
Export/Import All Log
This log contains information related to importing/exporting the settings with the Import/Export All function. (See "Import/Export Function.")
Log for Audit Log Management
This log contains information related to the exporting/deleting of logs with this function.
Managing Logs
You can use the Remote UI to manage the logs collected from the machine.
Please note that Canon will not be held responsible for any damages caused by the use of Audit Log Management or the inability to use Audit Log Management.
Advanced Box Operation Log is generated only when [Save Operation Log] is set to 'On'. For more information on [Save Operation Log], see "Specifying the Advanced Box Settings."
The maximum number of logs that can be managed with this function is 20,000, regardless of the type of log. When this maximum number is reached, the oldest logs are erased and overwritten with the new logs.
If Sleep Mode Energy Use is set to [High], logs are not collected when the machine enters the Sleep mode.
The logs described in this section may be collected multiple times by the machine's system processes during user operations.
In order to manage logs, it is necessary to log in to the Remote UI as an administrator.
The collected logs and exported logs include items for the Date and Time, User Name, Operation Type, and Result (OK/NG). Job logs also include items related to the job type.
To generate a Network Connection Log, Mail Box Authentication Log, Mail Box/Inbox Document Operation Log, Advanced Box Operation Log, System Management Log, select [Audit Log Retrieval] for [Audit Log Retrieval] in [Device Management] in [Management Settings] (Settings/Registration) → click [OK].
Starting/Stopping Log Collection
You can start or stop log collection. The collected logs are saved as a single audit log file.
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log] → [Audit Log Information] → [Start] for <Audit Log Collection>.
The saved logs may not be displayed in the order that they are collected.
Log collection is stopped by default.
If you start or stop log collection, this setting is retained until it is changed. The setting does not change when the machine is restarted.
If you stop log collection while logs are being collected, the logs for the period that log collection was stopped are not collected when log collection is next started.
Checking the Number of Saved Logs and the Date/Time They Were Collected/Saved
You can check the number of logs collected from the machine that are saved, and the date/time that they were collected/saved.
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log] → [Audit Log Information].
Current Number of Saved Logs:
Displays the number of logs that are currently saved.
Logs Last Collected On:
Displays the date/time that a log was last collected from the machine.
Logs Last Saved On:
Displays the date/time that a log collected from the machine was last saved.
Exporting Collected Logs
You can save the various logs collected from the machine all together to a computer in the CSV format.
The log type numbers indicated in the logs to be exported correspond to the following log types:
4098
1001/8193
Job Log
8197
8199
8196
8201
8202
8200
8198
3001
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log].
Click [Export] for <Export Audit Logs>.
To automatically delete the logs after they are exported, select [Delete logs from device after export].
If you select [Delete logs from device after export], make sure to select [Store] after clicking [Export]. If you select [Cancel], the logs will be deleted without being saved.
Follow the instructions on the screen to specify the location where you want to save the file.
To export the various logs collected from the machine, use SSL or IPSec. To use SSL, set [Use SSL] to 'On' in [Remote UI] in [Management Settings] (Settings/Registration). If you want to use IPSec, see "IPSec Settings."
Log collection is stopped while the export process is being performed.
If the display language setting of the machine is different from when the logs were collected, the file may contain garbled characters when the logs are exported.
Deleting Collected Logs
You can delete all the logs collected from the machine.
Click [Delete] for <Delete Audit Logs>.
Click [OK].
When an Error is Displayed
If you export or delete the logs when an error has occurred in the hard disk managed by this function, the message <Management area of audit logs may have been corrupted because an error occurred. The system will be initialized.> is displayed on the Remote UI.
Click [Initialize] to initialize the function.
If initialization is performed, log collection is stopped and all the logs that have been collected are deleted. To continue collecting logs, start log collection again.
