Top » Scanner » WSD Scan » Send Features of the WSD Scan
08KE-1CF
This section describes how to use the send features of the WSD Scan.
You can use the Push Scan function only in the following conditions:
Paper size:
LTR
Color mode:
Color
Resolutions:
300 dpi (fixed setting)
File format:
BMP, JPEG, PNG, TIFF
Place your originals.
You cannot scan 2-sided originals even if you are using a feeder. Place 1-sided originals.
The available scanning size is LTR. For example, if you set 11" x 17" originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
Press [WSD Scan].
Select the destination.
The computers, which are in the same domain and are equipped with the driver for WSD Scan functions, are listed.
4.
Press [Start].
If the destination [Scan to "computer name"] is selected:
If the destination other than [Scan to "computer name"] is selected:
A screen prompting you to select a program is appears. Scanning is complete after selecting the program.
The Windows Explorer starts and a scanned file is displayed.
Up to 40 destinations are displayed.
You cannot use [Send for OCR to "computer name"] when selecting the destination. If you want to use the OCR function, see "Searchable PDF/XPS/OOXML."
