Top » Flow of Settings » Operations Required Prior to Using the Machine
08KE-008
This section describes the flow of operations and settings required prior to using the machine, for the functions you will use.
Confirm the Following Settings
Some functions of the machine require optional products and operations/settings.
Also, if you want to use functions that require license registration, see "Adding New Functions." See the flowcharts in this category for functions that require operations or settings.
For information on the optional products required to use this function, see "Optional Products/Software."
For information on the system requirements for using the following functions, see "Optional Equipment and System Requirements."
Printing or Sending a Fax from a Computer for Printing (USB/network)
Using E-Mail/I-Fax for Scanning and sending (via e-mail/I-fax)
Sending Data for Scanning and sending (to a file server)
Function
Optional Product Required
License Registration
Operations Required
Copy
Duplex Color Image Reader Unit-G1
None
Scanning and Storing Files
Mail Box
None
Advanced Box/Network
Memory Media*2
Accessing Stored Files
Mail Box
None
None
None*1
Memory Media*2
None*1
Scanning and Sending Files
E-Mail/I-Fax
Sending Files to File Servers
Fax
Sending Files from the Machine
Duplex Color Image Reader Unit-G1 and Fax Board
Not Required
Receiving Files on the Machine
Fax Board
Not Required
None
Sending Files from a Computer via the Machine
Fax Board
Not Required
Sending and Receiving Files via the Remote Fax Server
Remote Fax Kit
Required
Print
UFR II Print
None
PCL Print
PCL Printer Kit
Required
PS Print
PS Printer Kit
Required
Barcode Print
Barcode Printing Kit
Required
Direct Print
None*1
Remote UI
None
MEAP Management Function (SMS)
None
Registering/Updating Software (Delivery)
None
Registering/Updating Software (Manual)
None
Scanning
*1
To print PDF files, the PS Printer Kit or Direct Print Kit (for PDF/XPS) is required. To print XPS files, the Direct Print Kit (for PDF/XPS) is required. Each optional product requires license registration.
*2
The default setting for displaying Memory Media is 'Off'. To use memory media, press [Display Settings] in [Preferences] (Settings/Registration) → set <Memory Media> in [Store Location Display Settings] to 'On'.
