e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Sending E-Mail/I-Faxes
Sending Data to a File Server
Opening the Advanced Box of the Machine Externally on the Network
Setting Up an Advanced Box on the Same Network
Using Memory Media
Directly Sending Faxes from the Machine
Sending and Receiving Faxes via the Remote Fax Server
Sending Faxes from a Computer via the Machine
Printing from a Computer
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Flow of Settings
08KE-00J
The following operations and settings are required to directly send faxes with the machine.
1. Specify the settings required for sending faxes.
Fax Line Settings
Current Date and Time
Printing the TX Terminal ID
To Practical Workflows
Automatically Forwarding Received Faxes
Handling Files with Forwarding Errors
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Back to Top
