Data You Can Back Up/Export
References
Document data in the Advanced Box
Document data in the Mail Box
Forms for the Superimpose Image mode
Address Book
Device Settings
Settings/Registration Settings Information
Printer Settings
Paper Information
Web Access Favorites
Quick Menu Information
User information of the Advanced Box
Data Relating to MEAP
License files for MEAP applications
Data saved from MEAP applications*1
Instruction manuals for each MEAP application
User authentication information registered for the Local Device Authentication system of SSO-H (Single Sign-On H)
By using the HDD Mirroring Kit, you can store the same data on two hard disks connected to the machine and synchronize them. Even in this case, we recommend that you regularly back up/export your important data, as it is possible that a malfunction in both hard disks may cause the data to be lost.
The passwords and PIN are backed up at the same time. However, some of the passwords may not be backed up, depending on the type of the password.
If your machine is not connected to a network, it is recommended that you print and store important information such as the Address Book. (See "Printing Reports.")
